dthrevan1
Mar 12, 2021Aspirant
Update cURL on ReadyNas Duo v1?
Hi, Is there anyway to update cURL so TLS 1.2 works on a ReadyNas Duo v1? Thanks
dthrevan1
Mar 31, 2021Aspirant
Duo V2
WhoCares_
Mar 31, 2021Mentor
Ok, and what command/action exactly is failing for you? WordPress itself should work - although there's no recent PHP version available so you'd probably find yourself stuck with PHP 5.6. Other than that I currently don't see why WordPress shouldn't work. Can you give me a list of the software installed on your ReadyNAS either manually or by way of add-ons, please. If you feel the information to be too sensitive for public display you can send it via PM.
-Stefan
