pjlet
Aug 01, 2014Aspirant
upgrade capacity of RNDX4000
Hi i have actually 4 hd 1 TO in xraid2 can i upgrade with hd wd 3 or 4 TO ? , perhaps 6 TO is it possible to upgrade only one or two disk ? thanks for your help pjl
vandermerwe
Aug 01, 2014Master
You need to upgrade 2 disks to get increased capacity.
You would need to do this one disk at a time, allowing the volume to complete a resync before upgrading the second disk.
Are there 6 tb disks on the HCL ? Can't view it at present.
