tbh999
Feb 18, 2012Star
Upgrade from NV+ to Ultra 4 Plus?
I have a ReadyNAS NV+ with what I think is a bad power supply, it's been down for over a week and I can't get any kind of response from NetGEAR about a replacement power supply (Case No. 17898527). I...
tbh999
Feb 18, 2012Star
Thanks, yes, every on-line store I typically use say that the PS is Back-Ordered, Discontinued or Special Order (Amazon.com, Buy.com, NewEqq.com, ProVantage.com, etc.). That's why I turned to customer service, It also turns out (after doing some research on this forum) that, my NV+ is in the range of S/N that had power supply issues.
I looked into buying an NV+ on eBay too, but, they're not that much of a bargain (they seem to be going for about $150, but I can buy a new one from NewEgg for ~$250).
