tbh999
Feb 18, 2012Star
Upgrade from NV+ to Ultra 4 Plus?
I have a ReadyNAS NV+ with what I think is a bad power supply, it's been down for over a week and I can't get any kind of response from NetGEAR about a replacement power supply (Case No. 17898527). I...
PapaBear1
Feb 18, 2012Apprentice
Unfortunately, the Netgear store is also showing the PSU as "Out of Stock". Your best bet is to give tech support another try. If you opened an on line case, you should have an e-mail contact. It seems that now instead of sending out a replacement PSU as they used to do, they are replacing the entire chassis, which may work in your favor if it possibly damaged the motherboard.
