mrbrown66
Jun 29, 2018Aspirant
Upgrade from RN104 to RN214
Hey guys,
I have an 4 bay RN104 on the latest firmware (6.9.3) and I am upgrading to an RN214 which is arriving shortly. Is it possible to move my 4 existing drives across and put them in the...
- Jun 30, 2018
mrbrown66 wrote:
Is it possible to move my 4 existing drives across and put them in the same slot order and it will simply work?
That works.
Though if you have a spare disk handy, you could do a fresh install on the disk, and (if needed) update the firmware on the RN214 first. Then power down and migrate the disks.
Jun 30, 2018Guru - Experienced User
That works.
