mrbrown66's avatar
mrbrown66
Upgrade from RN104 to RN214
Hey guys,    I have an 4 bay RN104 on the latest firmware (6.9.3) and I am upgrading to an RN214 which is arriving shortly.  Is it possible to move my 4 existing drives across and put them in the...
  • StephenB's avatar
    Jun 30, 2018
    mrbrown66 wrote:
    Is it possible to move my 4 existing drives across and put them in the same slot order and it will simply work?
    That works.
    Though if you have a spare disk handy, you could do a fresh install on the disk, and (if needed) update the firmware on the RN214 first.  Then power down and migrate the disks.
ProSupport for Business
