claytonb
Nov 02, 2011Aspirant
Upgrade Hard Drives
I'm looking at upgrading the drives in my ReadyNAS Ultra 4 Plus to SATA3 64MB will this unit support these drives or will it just drop back to SATA2?
1 Reply
- ReadySECUREApprenticeHello,
The ReadyNAS supports SATA 1 and 2, it will work with 3, however the speeds will be reduced to SATA 2 speeds. Make sure you are selecting hard drives from the compatibility list.
- http://www.readynas.com/?page_id=82
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
