pet2tso
May 23, 2016Aspirant
Upgrade Network switch for the ReadyNas RN104
I have a ReadyNas RN104 with 4 HD. It is attached to a Linksys Network Switch (100mpbs), using IP address 192.168.1.3, and the IP addr never changed for the last 2 years. I would like to upgrade th...
- May 26, 2016
Update: I bought a Netgear 5-port Gigabit Ethernet Switch - Model GS205 for $19.57.
It works like a charm the first time. I left my Netgear NAS RN104 on while making the switch over. No issue what so ever. Network connection is much faster now.
Thank you again to StephenB and JennyC for their timely advice !!
pet2tso
May 24, 2016Aspirant
Thank you both stephenB and JennC. Both of your answers reaffirmed each other. I have an ATT 2wire router/modem. This is a uVerse black fiber connection. What you have reaffirmed is that I am safe to swap out the network switch sitting between the 2wire router and the ReadyNas RN104. I have a Netgear 1gbps switch ordered. I feel comfortable to upgrade now. I will keep this forum updated. Thank you both again!!
- JennCMay 24, 2016NETGEAR Employee Retired
Hello pet2tso,
We greatly appreciate hearing your feedback letting us know that the information we provided has helped answering your question.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
