Grimleiv
Jan 26, 2024Tutor
Upgrade readynas 104
I have a readynas 104 with 2x10TB and 2x3TB, upgrading the 3TB to 16TB. Can i just remove one 3TB replace with a 16TB wile pwr on.. Wait for resync. When done same with nest?
- Jan 26, 2024
Can i just remove one 3TB replace with a 16TB wile pwr on.. Wait for resync. When done same with rest?
Yes, that will work. Assuming you are using X-RAID, then 2x10TB+2x16TB will give you 36 TB of storage (reported as ~32.75 TiB by the web UI). The resync will take a while, and the second resync will take longer quite a bit longer than the first.
Netgear recommends making sure you have an up-to-date backup before manipulating the disks (and FWIW, I agree with them on this). There is no RAID redundancy during the resync, so if one of the original disks fails during the process you will lose your data.
I also recommend testing the new disks in a Windows PC before putting them into the NAS. I always run the long non-destructive test, and follow that up with a full erase test. I have had some new drives pass one of these tests, but fail the other.
FWIW, the first resync will require 33 TB of disk I/O, the second will need 52 TB, so 85 TB in total. Doing a factory default with 2x10TB+2x16TB disks in place would require only 52 TB of disk I/O to create the volume, plus the I/O needed to restore the data from backup. So the factory default would be faster then one-by-one replacement (though it would require more manual steps).
Jan 26, 2024Guru - Experienced User
Grimleiv
Jan 29, 2024Tutor
Started on first drive, one hour in it says 71% done(up from 70%), remaining time swap between 58 and 80 hours every now and then. So all looks good 🙂
