Antonmk
Mar 17, 2021Aspirant
Upgrade to Quieter coolers on rackmont ready nas model RN 3138.
I bought on Amazon the ready nas RN 3138. I found it a little noisy. Would there be a way to replace the coolers with a quieter model? It comes equipped with 3 12V, 3 pin, 40x20mm coolers model MGT401...
Mar 18, 2021Guru - Experienced User
I believe that would void the warranty - though if you purchased it used, it wouldn't matter (since the warranty is not transferable).
