Antonmk
Mar 17, 2021Aspirant
Upgrade to Quieter coolers on rackmont ready nas model RN 3138.
I bought on Amazon the ready nas RN 3138. I found it a little noisy. Would there be a way to replace the coolers with a quieter model? It comes equipped with 3 12V, 3 pin, 40x20mm coolers model MGT401...
Mar 18, 2021Guru - Experienced User
I believe that would void the warranty - though if you purchased it used, it wouldn't matter (since the warranty is not transferable).
Antonmk
Mar 18, 2021Aspirant
I bought it from Amazon in the US, but I'm from Brazil, so I believe that the guarantee does not apply. In addition, it seems that during shipping the heatsink came loose, and ended up damaging a capacitor, which I soldered in place and that alone must have void the warranty anyway.
