Laserbait
Feb 28, 2023Luminary
Upgrading disks in a RN316
I have a RN316 populated with Seagate 4TB drives. Drives are getting really old now, and finally stating to fail after 6+ years of power on time. 🙂 I had disk 4 fail, and I replaced it with a 8...
- Mar 07, 2023
Sandshark wrote:
If you didn't enable XRAID, then you will not get that additional 4TB of space automatically added, nor can you add it via the GUI when in FlexRAID mode.
Leaving the mdstat printout aside, the web ui does show a volume size of 40 TB, so the volume does look like it expanded to 6x8TB RAID-5. It did not expand until the last disk was inserted, which is consistent with page 41 of the software manual.
