JS78
Jan 04, 2017Aspirant
Upgrading my Pioneer pro
I am planning "redoing" my RDNP600E to enable it to run Plex and OS6. I have multipe people streaming from my plex server However I find that availability of parts is challenging I am thinkin...
JS78
Jan 22, 2017Aspirant
JS78 wrote:I am planning "redoing" my RDNP600E to enable it to run Plex and OS6. I have multipe people streaming from my plex server
I am thinking of adding a X3230 CPU and adding GeIL Value Dual Channel GX24GB6400DC memory.
Three key questions:
- Is the X3230 the fastest CPU I can add or are there higher rated Passmark CPUs you would recommend that will fit?
- What cooler to put on the X3230 as stock coolers etc are no longer supplied with the CPUs I can get online?
- Will the GeIL memory work in the box?
thanks for sharing your thoughts and ideas
Hereby an update on the upgrade process. I am running successfully the 4GB dual channel GeIL memory I've bought.
I did manage to install a new Noctua CPU cooler by slighting hamering out the side of the case.
The X3230 arrived as well however I cannot get the heatsink removed from the CPU. It is completely stuck. I don't want to pull to hard as I am afraid I will break something. Does anyone have experience with this on replacing their CPU? I did try to get some dental floss between the heatsink and the CPU however I had no luck in getting it in between the both them.
JS78
I am running the new Noctua NF-8A fan to cool the CPU however I doesn't seem to run any faster than 727 RPM. Is there a way I can calibrate the fan or check if it can run at 2200 RPM as per specification.
Thanks for letting me know as well
