JS78
Jan 04, 2017Aspirant
Upgrading my Pioneer pro
I am planning "redoing" my RDNP600E to enable it to run Plex and OS6. I have multipe people streaming from my plex server However I find that availability of parts is challenging I am thinkin...
bedlam1
Jan 22, 2017Prodigy
Try gently heating the heatsink with a hairdryer i.e. replicating the CPU operating, and then try gently twisting and/or flossing
Also see HERE
JS78
Jan 22, 2017Aspirant
bedlam1 wrote:Try gently heating the heatsink with a hairdryer i.e. replicating the CPU operating, and then try gently twisting and/or flossing
Also see HERE
Can I just run hairdryer onto the unit? Will it have not impact on the mainboard or any of the surrounding components?
- bedlam1Jan 22, 2017Prodigy
I wouldn't recommend that
Edit: Oh hang on a moment, are you trying to get your old processor off?
If so just run your NAS and bring it up to temperature, switch off, and try removing the Heatsink whilst hot - The goal here is to soften the paste, which over extended use/time becomes an adhesive
- JS78Jan 22, 2017Aspirant
bedlam1 wrote:I wouldn't recommend that
Do I need to put some stress on the NAS or will any basic run temp do the trick?
I don't know but I guess the hotter you can get it the better
Edit: If that fails you need to soak the CPU in Rubbing Alcohol (Isopropyl Alcohol) to soften the paste
