JS78
Jan 04, 2017Aspirant
Upgrading my Pioneer pro
I am planning "redoing" my RDNP600E to enable it to run Plex and OS6. I have multipe people streaming from my plex server However I find that availability of parts is challenging I am thinkin...
JS78
Jan 23, 2017Aspirant
Sandshark wrote:No, you cannot access the CPU release lever with the heat sink still installed. Are you sure you have all the screws fully loose on the heatsink? I've replaced the processors on 3 older model Pro's and the headsink came free with a bit of a twist on all of them. But as long as you are sure you have them loose, just unplug the fan and run the unit for a bit. The CPU will heat up pretty fast, and you don't care what happens with it, anyway.
As far as a cooler goes, good luck finding anyting that will fit in the space provided. The stock cooler is extremely low profile. You would have been better off buying a Core 2 E7600, which is still a 65W TDP processor, than the Xeon X3230, which is 95W TDP, as they have very similar performance and you would have no heat problem with the stock cooler. At current eBay prices, it's not a costly thing to change. I have two running an E6600 and one an E7500, purchased when the prices were higher (with a big premium on the E7600), all with the stock cooler and no heat issues.
You will get better performance with more memory with a ratng of 5-5-5-15. But as far as I've been able to tell, the motherboard does not run in dual channel mode. So you won't get as much improvement as you expect.
As far as the motherboard version is concerned, if it says "Flame6 V1.1" in the area between the CPU and RAM, it's the latest..
Finally I managed. I ran the system briefly without fan and the heatsink just popped off!
I've installed the X3230 and I've installed a Noctua NF-A8 CPU fan and a Noctua NF-S12A system fan now.
The system is running plex and is building the library now. System temps seem to be normal even slightly lower than normal even (old CPU, old fans)
Thanks everyone for offering your thoughts and ideas. For now all seems to be running successfully
JS78
running the system for a while now and I did a small test.
Running two transcoding streams and one live stream from various Plex devices
I get the following
Without too much of a load (just serving some data and running the PLEX library scans) I get the following
Not sure if that is bad Sandshark, would appreciate a perspective
- SandsharkJan 24, 2017Sensei
CPU temperatures are never all that accurate. I've never seen mine get that high except when my air conditioner went out, but I don't run Plex transcodes on it, either. If "CPU temperature" is case temperature (I'm really not sure), then you are above the recommended limit of 60.4°C. If it's junction temp (which seems more like what "core" temp would be), you are below the 85°C limit.
- kekegsmApr 07, 2017Guide
What do you think guys, can the Xeon L3110 work in the Pro? It is only 45W, and higher performance as E7600, but it has 1333FSB...
- SandsharkApr 08, 2017Sensei
Support for the L3110 is pretty scarce in motherboards, even those supporting other 1333MHz FSB CPUs. I can't recall anyone having luck with 1333MHz FSB CPU's in the Pro6 and sincerely doubt it supports this one, especially.
