SolwayMist's avatar
SolwayMist
Upgrading OS6 to newer versions
After upgrading my ReadyNAS Pro 6 from Radiator 4.2.31 to OS6 (6.3.5) what is the highest version of OS6 I can install without encountering problems.
  • Sandshark's avatar
    Jul 08, 2017
    There was no need to move to such an old version of OS6 on your legacy NAS.  You must have downloaded that file a long time ago, as the download is kept current with the latest version here on the forum.  That said, you can go all the way to 6.8.0 beta 2 if you like.  You can just use the built-in update to go to 6.7.5.  No need for anything special once you've got an OS6 system.
