SolwayMist
Jul 08, 2017Aspirant
Upgrading OS6 to newer versions
After upgrading my ReadyNAS Pro 6 from Radiator 4.2.31 to OS6 (6.3.5) what is the highest version of OS6 I can install without encountering problems.
- Jul 08, 2017
There was no need to move to such an old version of OS6 on your legacy NAS. You must have downloaded that file a long time ago, as the download is kept current with the latest version here on the forum. That said, you can go all the way to 6.8.0 beta 2 if you like. You can just use the built-in update to go to 6.7.5. No need for anything special once you've got an OS6 system.
Sandshark
Jul 08, 2017Sensei
SolwayMist
Where is the latest upgrade file then as I cannot find it on the forum.
- SandsharkJul 09, 2017Sensei
