cctsupport
Oct 22, 2020Aspirant
USB Backup - Does it keep sets?
Hi All I've got this readyNAS that's going snapshots. However, it doesnt go as far as i want it to. I've got a USB backup and I was hoping maying I could get the file from there. Does the...
Oct 22, 2020Guru - Experienced User
cctsupport wrote:
Does the USB backup just copy the data at that time or does it create sets?
It just copies files. If you use the default settings, then files that you delete on the NAS should still be on the USB backup. But if the file was modified, you'll just find the most recent version that was backed up.
