MattRDude's avatar
MattRDude
Follower
Aug 07, 2019
usb capabilities of RN424
Hello,
I am interested in purchasing a Netgear RN424 Storage Cabinet.  However, I don't want to use it as a NAS or SAN.  I want to direct connect via usb3 cable to one computer.  If I first insert 4 drives and configure them as a RAID array, and then connect the RN424 via usb cable, will my computer see the RN424 as an external disk?
Thank you,
-MR
  • schumaku's avatar
    schumaku
    No, a NAS does not make an external RAID disk enclosure - and no for various reasons:
    1. The USB ports - even if USB 3.0 does sometimes use USB-C type ports - are still requiring a USB host and a USB device. The ReadyNAS is always USB host, and two hosts can't be interconnected.
    2. A USB storage device is always a USB client, and does make use of the USB Mass Storage Protocol - this requires direct "block" access to the volume. This isn't available on ReadyNAS.
    3. ReadyNAS does put up a RAID and runs a one or multiple volume(s) with a file system (BTRFS), or some iSCSI accessible block devices only - the access to a ReadyNAS must be always IP based either way.
    4. Some vendors have a USB direct attach option (e.g. QNAP) - this is implemented as a 1Gb Ethernet, and the access is again IP based (over the USB data link).
    5. Latest developments in the NAS arena are capabilities to use a NAS as true DAS/SAN - but this is based on FiberChannel (and again an industry first by QNAP).
    Disclaimer: Yes, I have some relations to QNAP, but I'm not an employee.
    • Retired_Member's avatar
      Retired_Member
      Fantec has one with 8 bays, too.
      • Sandshark's avatar
        Sandshark
        Sensei
        A DAS (Direct Attached Storage) and NAS (Network Attached Storage) are completely different things.  I believe the OP wants a DAS, though he may want a dual-purpose DAS/NAS.  He has come to the wrong place, because Netgear is not in the DAS business.  I have only ever known of one true dual-purpose DAS/NAS, and the same files could not be shared between the two access methods.  The DAS area operated much like iSCSI, as a block of space formatted and accessed by the computer using it, not the NAS, and that area was walled off from NAS access..
        Other that the Thunderbolt2 device from QNAP mentioned (which is using Thunderbolt2 as a network transport, so that's "cheating"), the other devices listed are DAS.  Some are DAS intended for connection to a computer (but will likely also work attached to a NAS) and others are intended for attachment to a NAS as expansion (but may work attached to a computer).  But none of the others will work as both.
        The basic answer to the original questions is:  It can't be done.
ProSupport for Business
