queirozfl
Jul 01, 2016Aspirant
USB Flash with OS Radiator 4.2 is dead
Hello, i have a big probleam, a few days ago my readynas 4200 torn off and doesn't start boot, the usb flash with OS Radiator is Dead, Someone can help me, how to install the Radiator in a new usb fl...
omicron_persei8
Jul 02, 2016Luminary
Are you actually sure that the flash card is physically dead? Or do you "just" have boot issue?
How did you determine that? The OS runs from the HDDs, not from the flash. The flash contains the firmware for when you Factory Default the NAS and the boot menu.
- StephenBJul 02, 2016Guru - Experienced User
How did you determine that? The OS runs from the HDDs, not from the flash. The flash contains the firmware for when you Factory Default the NAS and the boot menu.Try removing all the disks (labeling by slot) and installing a blank (unformatted) drive in slot 1. Then power on the NAS and see if it does a factory install.
