tsimmo67
Feb 12, 2016Aspirant
Using Ready NAS 104 as individual volumes for long term storage of multimedia files
Hi all, I have recently purchased a Ready nas 4 bay system, with 3x 4tb seagate harddrives. The plan is to use this as a long term storage solution for my partners photography business, which...
mdgm-ntgr
Feb 12, 2016NETGEAR Employee Retired
Using X-RAID you would have a single volume across all the disks. With three disks you would have a RAID-5 volume. What you want is to disable X-RAID and to create the volumes that you want (a separate volume for each disk).
It is advisable not to fill a volume more than about 80% for optimal performance.
Note that SATA connectors are designed for a limited number of pulls. If you do this regularly you may shorten the life of the SATA connectors. Also if the data is important you should keep multiple copies of the data on different devices.
When you remove a disk it is expected that the removed disk is one you no longer wish to use (e.g. because it's failed or you want to use a higher capacity disk instead).
With a single disk that has a single disk volume on it though if you power down the NAS and remove your disks (label order) and put that disk back in and power on you should be able to access the data.
However you can damage disks handling them bare e.g. through Electro-Static Discharge.
I understand what you are tryng to do, but I don't think this is the best way to go about it.
Welcome to the Community!
- tsimmo67Feb 12, 2016Aspirant
Thanks.
My local computer store recommended NAS as the best storage solution, which is somewhat frustrating.
I had assumed that given you can hotswap HDD's, it wouldn't be any different to reconnecting an old HDD in order to access the files stored on there. At the moment we are using external Hdd's, but those things are rubbish for long term storage.
- StephenBFeb 12, 2016Guru - Experienced User
tsimmo67 wrote:
Thanks.
ReadyNAS supports hot-insertion for disk replacement, but it doesn't support routinely removing and remounting volumes.
How much data are you talking about (and what is the approx. growth rate)?
We are looking at approx 10-12tb of data as it stands, with a growth rate of approx 3tbs a year, depending upon how much work comes our way. This is weddings and dance concerts, so needs to be accessible in the long term. I am also advocating Cloud storage as well.
Given that the NAS system and tyhe 3 harddrives came to around a thousand dollars, I better be able to make it work, or I might be sleeping on the couch for a while! :)
