dbott67
Mar 03, 2008Guide
Using the ReadyNAS to create a Network UPS for PCs
The ReadyNAS can issue "UPS commands" to other devices, effectively allowing your UPS to be networked and shutdown client PCs. I've got my UPS connected to the NAS and setup using the procedure below...
jcollins
Mar 06, 2008Aspirant
As a side note, I think this is only useful if you have the PC on the same UPS as the ReadyNAS. Otherwise the PC (which draws more power) will die before the ReadyNAS UPS's does.
