dbott67
Mar 03, 2008Guide
Using the ReadyNAS to create a Network UPS for PCs
The ReadyNAS can issue "UPS commands" to other devices, effectively allowing your UPS to be networked and shutdown client PCs. I've got my UPS connected to the NAS and setup using the procedure below...
essd
Jan 20, 2009Aspirant
THN wrote: Dave, thanks for the great instructions, but I am a little hesitant to go down that road, because super-poussin said:
super-poussin wrote: Just a little Information : it will not work with duo
When super-poussin wrote that, I believe he was referring only to the built-in FrontView user interface for enabling UPS sharing (which is present in only the NV+ models). It's true that the Duo does not have this option exposed in the UI, but my instructions (two posts up) should have exactly the same effect as that UI setting.
You don't need to install the SNMP add-on to do this. I have a Duo myself and I can confirm that the UPS sharing is working using the instructions above without any extra add-ons. (SNMP might allow you to monitor other things on the device, but it's not needed in this particular instance.)
If you're nervous, you can always make a backup copy of those config files so that you can revert in the case of trouble (which I'd recommend as a good general practice anyway).
