dbott67
Mar 03, 2008Guide
Using the ReadyNAS to create a Network UPS for PCs
The ReadyNAS can issue "UPS commands" to other devices, effectively allowing your UPS to be networked and shutdown client PCs. I've got my UPS connected to the NAS and setup using the procedure below...
THN
Jan 21, 2009Aspirant
Thanks for the reply essd. I had read your instructions, which are very clear and concise. However, I wanted to kind of stay away from installing the root access. Hence my question regarding the SNMP. If installing that, will allow me to monitor my NAS from a PC, that's really all I need.
When you say:
When you say:
does that mean that it'll allow me to monitor my NAS UPS signals from a networked PC?
but it's not needed in this particular instance.)
