dbott67
Mar 03, 2008Guide
Using the ReadyNAS to create a Network UPS for PCs
The ReadyNAS can issue "UPS commands" to other devices, effectively allowing your UPS to be networked and shutdown client PCs. I've got my UPS connected to the NAS and setup using the procedure below...
erincal
Aug 02, 2010Aspirant
dbott67
That post has very good info. I have a question for you.When you edit your configuration file,in the very first entry is the user and password the ones you use to access your ready nas?
Also when click on apply on start Win nut I get a box that states insufficient power configured.Edit your configuration and change the values.This may be that my battery is low on the ups maybe not.Does it work for the Ready Nas Duo.Someone posted it does not.
