dbott67
Mar 03, 2008Guide
Using the ReadyNAS to create a Network UPS for PCs
The ReadyNAS can issue "UPS commands" to other devices, effectively allowing your UPS to be networked and shutdown client PCs. I've got my UPS connected to the NAS and setup using the procedure below...
tijgert
Sep 21, 2011Guide
I'm having some difficulty figuring out if I'm doing it right or wrong...
I have "MONITOR [email protected] 1 monuser pass slave" in my Winnut settings, like most people here, but I don't know if this applies to my setup.
I have a RNDU6000 NAS and an APC BE700G-GR UPS.
Do all the UPS's use 'UPS' as the name?
The IP is the IP for my NAS, that's the only thing I was sure about *gg*.
But then there's the login/pw... do I ALWAYS use this monuser/pass combo? (and why?) Or do I fill in what I use in my NAS? (login admin, PW {somethingsecret}), Or perhaps my main computer login/PW?
My logfile for when I use the monuser/pass combo says:
Level INFO 09/22/2011 05:44:42 Detected OS as Windows NT
Level NOTICE 09/22/2011 05:44:42 Network UPS Tools upsmon 2.0.0b
Level INFO 09/22/2011 05:44:42 UPS: [email protected] (slave) (power value 1)
Level INFO 09/22/2011 05:44:42 Config Load: MINSUPPLIES set to 1
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYCMD set to c:\Program Files\WinNUT\alertPopup.exe
Level INFO 09/22/2011 05:44:42 Config Load: POLLFREQ set to 5
Level INFO 09/22/2011 05:44:42 Config Load: POLLFREQALERT set to 5
Level INFO 09/22/2011 05:44:42 Config Load: HOSTSYNC set to 15
Level INFO 09/22/2011 05:44:42 Config Load: DEADTIME set to 15
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYMSG set to ONLINE : UPS %s is getting line power
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYMSG set to ONBATT : Someone pulled the plug on %s
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYMSG set to LOWBATT : UPS has a low battery
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYMSG set to SHUTDOWN : The system is being shutdown
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYFLAG set to ONLINE : EXEC
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYFLAG set to ONBATT : EXEC
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYFLAG set to LOWBATT : EXEC
Level INFO 09/22/2011 05:44:42 Config Load: NOTIFYFLAG set to SHUTDOWN : EXEC
Level INFO 09/22/2011 05:44:42 Config Load: RBWARNTIME set to 43200
Level INFO 09/22/2011 05:44:42 Config Load: NOCOMMWARNTIME set to 300
Level INFO 09/22/2011 05:44:42 Config Load: FINALDELAY set to 5
And nothing else. So I don't see anything about things being polled correctly anywhere...
Anyone can set me straight?
