gwhite's avatar
gwhite
Guide
Mar 04, 2024
Using WinNUT Client with ReadyNAS 312?
I have a new CyberPower UPS, which I have connected via USB to my RN312.  It is all set up to shutdown the NAS using the "Auto" threshold, which I believe is 5 minutes of remaining run-time.   I al...
  • gwhite's avatar
    Mar 04, 2024
    It turns out the version I got was from an older "fork" on GitHub, and I needed to get the  latest version here:
    https://github.com/nutdotnet/WinNUT-Client?tab=readme-ov-file
    I installed this one, and configured the communications window like this:
    No login info required.  I only put in the NAS IP address, and changed the UPS name.  It connected immediately!
    The only other important settings I changed were the Shutdown Options:
    The default shutdown runtime was set to 120 seconds.  If the NAS shuts down at 5 minutes remaining runtime, that will be a problem.  I set the PC shutdown time to 6 minutes so it will shut down first.  Without that load, the run time should jump way up, and the NAS will run a lot longer.
    It looks like it's all working.  I'm not sure I have the nerve to test it at the moment...
    I hope this info helps others.  I think this approach is WAY simpler than all the others I investigated.
ProSupport for Business
