mikenico
Dec 11, 2016Aspirant
Very Angry
I just got out my ready duo nas drive because I moved home, and set it up all was great everthing was working great, I then when into the menu and did a quick update test and the software prompted be...
mdgm-ntgr
Dec 11, 2016NETGEAR Employee Retired
Have you tried disconnecting the power, then reconnecting it and seeing if you turn it on again if it boots fine?
Is your backup up to date?
