mikenico
Dec 11, 2016Aspirant
Very Angry
I just got out my ready duo nas drive because I moved home, and set it up all was great everthing was working great, I then when into the menu and did a quick update test and the software prompted be...
mikenico
I do welcome help from the forums and other members which a great thing, but a loyal customer of any make or product should recive support many compainies do this why Netgear is an exception is beyond me, if the wish to keep customers loyal then asking them to pay for support is only going to loose them customers.
mdgm-ntgr
Dec 12, 2016NETGEAR Employee Retired
It's close to 7 years since your software warranty expired and over four years since the hardware warranty expired.
We are not an exception in doing this. Expecting to be able to call up and get free help via official support channels forever when you can use the community to get help is quite unrealistic.
This problem likely could be resolvable via the community. If my suggestion above doesn't resolve it there are other things that can be tried.
Anyway as a last resort you could do a factory default (wipes all data, settings, everything) and restore from your regular backup (assuming you have one which you should) which hopefully you updated shortly before doing the firmware update as per best practice.
- JBDragon1Dec 19, 2016Virtuoso
Will doing a OS Reinstall bootup fix the issue? That wouldn't delete the Data on the system. I assume that's possible?
A Real backup of your data of course is always a good thing as a NAS is not a backup solution unless you're backing up to a second NAS. You can keep saying this, but sometimes people just arn't thinking. I do it myself at times.
- mdgm-ntgrDec 19, 2016NETGEAR Employee Retired
An OS Re-install fixes a very limited range of problems and if certain problems are present can introduce new problems.
There's not enough information in this thread to know what the solution is for sure. More troubleshooting would be needed to determine that.- JBDragon1Dec 19, 2016Virtuoso
Which is why I said to call Netgear and see if they'll help, even though SSH was being used. I know a few holes need to be filled in, but hard shutting down the system like he did while the system was busy is not a good thing.
