matthew-m
Jan 04, 2021Aspirant
VM image for RAIDiator
Does anyone have a guide to run ReadyNAS OS4 (RAIDiator) in a Virtual Machine? (VirtualBox or KVM). I found https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/RAIDiator-x86-4-2-28-Vir...
- Jan 04, 2021
Here is a new upload of that: RAIDiator-x86-4.2.28.ova
Note the VM uses an OS6 kernel so you can't use it to test kernel modules but for testing most other non-hardware specific things in the OS it should be fine.
mdgm
Jan 04, 2021Virtuoso
- SandsharkJan 05, 2021Sensei
See also this message: How-to-update-RAIDiator-4-2-28-Virtual-Machine-to-4-2-31 . I found it to be the cleanest way to do it.
- matthew-mJan 05, 2021Aspirant
Thank you all. This ova file worked like a charm.
