capea4
Jan 13, 2018Aspirant
Volume disappeared overnight. no drives failed, nothing in logs
Hello pros! I have been using this NAS since 2011 without many issues. Its holds a vast media library that is accessed by apple tvs in 7 locations using the Infuse app. I did upgrade it to os6 last ...
capea4
this is what the log is full of page after page
Marc_V
Jan 22, 2018NETGEAR Employee Retired
Hi capea4
Welcome to the Community!
Do you have fuil and updated backup of your data? Might possibly be a Filesystem error or a full volume capacity that got the NAS in this situation.
Have you tried booting your NAS on Read Only Mode? If you can try and see if it will let you, kindly download your data.
Were you able to download the logs? You can send this to us through PM by Google drive or Dropbox.
If you have your data backed up, it might be wise to do a Factory Default instead.
You may also want to PM mdgm-ntgr as he might be able to help
Regards
- capea4Jan 22, 2018Aspirant
it WAS a "key error" in the superblock. it wanted one number higher than i had. i deleted the superblock info witch removed the btrfs file system. thats when i gave up and made a new md127 and tryed to sync it. didnt work. lost everything and started over
thanks though
charlie
