bearklaw23
Jan 30, 2021Aspirant
Volume went from Redundant to Dead overnight - recoverable?
I have a ReadyNAS 516 with 6x 4TB WD Red drives. This morning the shares had vanished from my network, and the ReadyNAS wasn't responsive to the front panel buttons. Drive 6 had a red light next to it as if it had failed. I eventually had to turn the power off to get the box to respond, and when it restarted it showed all six drives as healthy, but there was no volume, and it had split the drives from a single RAID-X volume into a RAID 5 volume and a RAID 1 volume. The logs simple show "Volume data health changed from Redundant to Degraded" with no indication of an error, and about an hour later "Volume data health changed from Degraded to Dead" at the same time it shows drive 6 as having failed. I've tried rebooting with drive 6 present and removed and it has no effect on the system when it comes up.
I have a fairly recent backup so my data is safe, but I would rather recover the volume than restore 18GB of data. Is there any chance of salvaging my data at this point?
- bearklaw23Aspirant
Update - the logs show it is rejecting disk 2 at boot time, even though the disk shows as healthy. With 2 and 6 not registering the volume is indeed dead. I did notice there is a lot of dust in the unit - I'll take all the drives out, clean it out with compressed air, reseat all the drives and see what happens.
I wish I knew why it was rejecting disk 2, all the logs show is that it boots up, see's all five drives, then "kicking non-fresh sdb3 from array!" Some form of corruption?
Cleaned everything up, made sure the drives were seated properly, same condition. When starting up the logs show
Jan 30 13:13:46 nasgul kernel: md: md126 stopped.
Jan 30 13:13:46 nasgul kernel: md: bind<sdb3>
Jan 30 13:13:46 nasgul kernel: md: bind<sdc3>
Jan 30 13:13:46 nasgul kernel: md: bind<sdd3>
Jan 30 13:13:46 nasgul kernel: md: bind<sde3>
Jan 30 13:13:46 nasgul kernel: md: bind<sdf3>
Jan 30 13:13:46 nasgul kernel: md: bind<sda3>
Jan 30 13:13:46 nasgul kernel: md: kicking non-fresh sdf3 from array!
Jan 30 13:13:46 nasgul kernel: md: unbind<sdf3>
Jan 30 13:13:46 nasgul kernel: md: export_rdev(sdf3)
Jan 30 13:13:46 nasgul kernel: md: kicking non-fresh sdb3 from array!
Jan 30 13:13:46 nasgul kernel: md: unbind<sdb3>
Jan 30 13:13:46 nasgul kernel: md: export_rdev(sdb3)
Jan 30 13:13:46 nasgul kernel: md/raid:md126: device sda3 operational as raid disk 0
Jan 30 13:13:46 nasgul kernel: md/raid:md126: device sde3 operational as raid disk 4
Jan 30 13:13:46 nasgul kernel: md/raid:md126: device sdd3 operational as raid disk 3
Jan 30 13:13:46 nasgul kernel: md/raid:md126: device sdc3 operational as raid disk 2
Jan 30 13:13:46 nasgul kernel: md/raid:md126: allocated 6474kB
Jan 30 13:13:46 nasgul kernel: md/raid:md126: not enough operational devices (2/6 failed)
Jan 30 13:13:46 nasgul kernel: RAID conf printout:
Jan 30 13:13:46 nasgul kernel: --- level:5 rd:6 wd:4
Jan 30 13:13:46 nasgul kernel: disk 0, o:1, dev:sda3
Jan 30 13:13:46 nasgul kernel: disk 2, o:1, dev:sdc3
Jan 30 13:13:46 nasgul kernel: disk 3, o:1, dev:sdd3
Jan 30 13:13:46 nasgul kernel: disk 4, o:1, dev:sde3
Jan 30 13:13:46 nasgul kernel: md/raid:md126: failed to run raid set.
Jan 30 13:13:46 nasgul kernel: md: pers->run() failed ...
Both suspect drives (2 and 6) show no ATA errors, but started reporting "1 Current Pending Sectors" in the last 3 days. I'm guessing I need to get /dev/md126 to accept one of the two drives to access my data, but I'm not sure how to accomplish this. Could mdadm be used to try and assemble the array again?
There is a flag that would force the assembly. You could end up with file system corruption though.
