ndpm's avatar
ndpm
Vulnerabilities on Ready NAS 204
We did a scan to our network and found severals vulnerabilities in our NAS 204.
I look online but was not able to find anything.
here is the list:
1: SSL Medium Strength Cipher Suites Supported
2: Apache 2.2.x < 2.2.33-dev / 2.4.x < 2.4.26 Multiple Vulnerabilities
3: Apache 2.2.x < 2.2.34 Multiple Vulnerabilities
4: SSL 64-bit Block Size Cipher Suites Supported (SWEET32)
5: SSL Certificate Cannot Be Trusted
6: SSL Certificate with Wrong Hostname
Can you help me to fix this.
Thank you.
  • StephenB's avatar
    You can't fix (5) unless you arrange to install a cert from a CA.  The NAS uses a self-signed cert.
    What firmware are you running?
      • StephenB's avatar
        I'm running 6.8.0-RC1 on mine.
        I checked with www.ssllabs.com
        I got the expected self-signed cert issues
        Alternative names -   INVALID
        DNS CAA No
        Trusted No   NOT TRUSTED
        It also got a downgrade on forward secrecy - details are
        TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 (0x9e)   DH 1024 bits   FS   WEAK
        TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 (0x9f)   DH 1024 bits   FS   WEAK
        TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 (0x67)   DH 1024 bits   FS   WEAK
        TLS_DHE_RSA_WITH_AES_128_CBC_SHA (0x33)   DH 1024 bits   FS   WEAK
        TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 (0x6b)   DH 1024 bits   FS   WEAK
        TLS_DHE_RSA_WITH_AES_256_CBC_SHA (0x39)   DH 1024 bits   FS   WEAK
        TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA (0x88)   DH 1024 bits   FS   WEAK
        TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA (0x45)   DH 1024 bits   FS   WEAK
        There was one encryption method with a 112 bit key that was also flagged.
        TLS_RSA_WITH_3DES_EDE_CBC_SHA (0xa)   WEAK
        These are easily fixed by Netgear - removing one cipher suite, and changing the minimum DH key size.
  • kohdee's avatar
    kohdee
    NETGEAR Expert
    Things that help NETGEAR better diagnose these issues are also knowing which software you used to generate this report, and a copy of the report....  What you've provided here is not really explicit to any specifically known vulnerabilitiy. CVE numbers help here.
    On your apache2 problems, if your scanner only checks version, then you cannot trust that. We do lots of cherrypicking from newer versions and put fixes in seemingly older versions. So likely, these are not realistic. We also do this in kernel and other things.
    You could eliminate 4 of those by using HTTP instead of HTTPS :P
    • ndpm's avatar
      ndpm
      Nobody from Netgear try to contact me to get the report.
      The scans are done with Tenable IO.
      • StephenB's avatar
        Both kohdee and mdgm-ntgr work for Netgear.
        You could perhaps PM Kohdee and send him a copy of the full report.
  • This reply was moved to another post
ProSupport for Business
