chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20...
mdgm-ntgr
Mar 27, 2010NETGEAR Employee Retired
WDIDLE3 maybe if the drive supports it (if you need this you will notice the Load Cycle Count increasing in SMART stats). 4.1.7 beta should mean that WDTLER isn't required I think (as 4.1.7 is supposed to fix the TLER issue), but if you can use it on the drive it shouldn't hurt.
Han Solo wrote:
mattseattle wrote: So what is the deal with Load Cycle count that I keep reading about on here?
This has to do with WD desktop class drives showing a high number of load/unloads. WD has a program called "wdidle3" I think that allows you to change the default value on the drive to a longer time. I asked WD what would be the recommend time interval to change it to and they said 5 minutes.
