chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20...
roadfun
Mar 27, 2010Aspirant
Using the 4.1.7 beta I got the -00S8B1 to work in my Duo however the LCC count climbs steadily which in the long run is a bad thing. It seems the drive will work but will likely fail sooner than you might expect.
I really need a 2x2TB solution for my Duo. Not sure what options exist given the limited HCL info and the fact there isn't even a way to know what "suffix" of WD20EARS you're going to get when you order them. WD and Netgear should work something out rather than burning customers. I was hoping to find upgrading to a different ReadyNAS model would solve this problem but that doesn't seem to be the case based on this forum. Synology claims support but I'm not 100% certain that means the LCC issue doesn't exist in their NAS.
