chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20...
mdgm-ntgr
Mar 28, 2010NETGEAR Employee Retired
If you insert used disks you should make sure they only have one partition and hot-add (add while NAS is on). Hot-adding should work in most cases for used or new disks that are compatible. If necessary you can low-level format used disks using vendor tools (I think) before adding them.
