chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20...
mdgm-ntgr
Mar 28, 2010NETGEAR Employee Retired
OzzyJim wrote: If that doesn't work, how should I phrase the problem in the RMA to WD?
Well you should probably see if you can run vendor tools on them using a PC. If they fail those tests or if they aren't recognised at all by the PC you can mention that.
It's possible the disks were already dying by the time you used the utilities.
