chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20...
efalsken
May 25, 2010Aspirant
TLER is just an extra step you can take to prevent the controller from thinking the drive is dead/dying while the drive goes into extended recovery. It only kicks in WHEN the drive develops a bad sector. (more often than you'd think, its usually transparent)
If you don't run TLER, and you get a report of a dead drive.....don't worry. Just power the ReadyNAS off, and back on again. The drive will, in all likelihood show up green. If it doesn't, then the drive really did die. :)
