chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20...
woodenbelly
Jun 13, 2010Aspirant
Hi everybody
I am having the same problems with these drives my duo is only 4 weeks old and i decided to take the plunge upto higher capacity drives
luckily the new drives i recieved are the correct ones listed in the compatability list but after 2 days of use one of my drives was listed as almost dead.
I am currently using my duo in flex raid configuration and using Raidar 4.3.0 at this moment in time i only have 1 disk in use.
my duo was set up with an older version of raidar and firmware 4.1.6 / which is currently in use
will updating to raidiator 4.1.7-T42 allow me use my other disk??
Model: WDC WD20EARS-00S8B1
Serial: WD-WCAVY3645801
Firmware: 80.00A80
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 8166
Start Stop Count 30
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 77
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 12
Power-Off Retract Count 11
Load Cycle Count 3501
Temperature Celsius 38
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 102
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 132
Power glitches 0
Hard disk resets 0
Retries 0
Firmware: 80.00A80
SMART Attribute
Spin Up Time 8166
Start Stop Count 30
Seek Error Rate 0
Power On Hours 77
Spin Retry Count 0
ATA Error Count 102
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 132
Power glitches 0
Hard disk resets 0
Retries 0
