chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20EADS which might have been a candidate (if not discontinued in a near future) seems to have a lot a quality and compatibility issues.
But ... :
1) The HCL mentions the exact version to be used: WD20EARS-00R6B0. Googling the reference does not provide any answer (but the WD20EADS-00R6B0 which is well known). AFAIK, the current available version of the drive is the WD20EARS-00S8B1.
There should be an error in the HCL or the new entry is useless !
2) No restriction appears on the RAIDiator version to be used meaning by the way that the new 4K sector size, which implementation starts in high capacity drives such as the EARS, is fully supported since the beginning. It's amazing as other vendors have delivered updated firmwares for that specific purpose (and keep partitions aligned or performance may degrade significantly).
Or will the 4K sector size be supported by RAIDiator 4.1.7 as current beta "adds support for WD drives that don’t support TLER" (= WD desktop drives) ?
And does this new entry in the offical HCL mean that LCC issues are now fully tackled by RAIDiator 4.1.7 (since the EARS has the same green features as the EADS and WDIDLE is not supported by WD on newer drives), even though some users report recent WD firmwares do not count any more Intellipark related LCC in the Smart infos ?
Please Jedis clarify and thanks to still supporting early (Infrant ...) adopters !
Regards.
But ... :
Regards.
- mdgm-ntgrNETGEAR Employee Retired
OzzyJim wrote:
the factory reset worked on the second attempt. Currently sync'n the 2nd drive. Not sure whether the problem was WDTLER or possibly putting the drives back in the wrong bay. (What does happen if you swap the drives after shutdown?)
It's best to put drives back in the correct bay. Putting them in the wrong bay after shutdown may work with recent firmware, but why take a risk if you don't have to. - WebaccessAspirantHi All,
I think I found this topic just like most of you: Because of problems.
Below the story of my ReadyNAS NV+ in combination with the WD20EARS-00S8B1 drives:
Initial Setup:
1 * ReadyNAS NV+
1 * 1GB Memory
4 * Seagate ST31500341AS 1.5TB Drives (X-RAID)
RAIDator version 4.1.6
Used space about 98%
Checked the HCL for larger disks and found the WD20EARS drives.
Large, not to expensive and altrough not the fastest disk I thought the 64MB memory would help more than a higher rotating speed. So I ordered 4 of those disks to replace the currect 1.5TB disks.
I received for identical disks:
Model - WDC WD20EARS-00S8B1
Firmware - 80.00A80
Replaced one of the current disks with a brand new 2TB drive and... nothing. Removed the drive and then, searing the internet, I found this topic and made the decision to install the lastest beta firmware 4.1.7-T29. Reinstalled the disk again and it was recognized correctly. Waited about 7,5 hours to let the disk initialize and an additional 6,5 hour for the RAID Sync to compleet. I Repeated the steps for all four disks and restarted the system for the Volume Expansion to take place.
Now I got into throuble as the system don't start correctly. for several hour I only saw a blue flashing power button and on the display "Booting, please wait ...". I waited for at least 48 hour but still no result. In the end I just pulled the power cord and restarted the complete system again. Now it started up without problems and gave a message that a reboor was required to start to Volume expansion. With the third restart the expansion started I now I looking at the system with 5.4TB of storage.
BUT, the Load Cycle Count is high and still raising. Depending on the disk I'm looking at its between 200 and 400.
Disk1 - Power on hours: 80 - Load Cycle Count - 377 (two minutes later 385)
Disk2 - Power on hours: 73 - Load Cycle Count - 360
Disk3 - Power on hours: 49 - Load Cycle Count - 214
Disk4 - Power on hours: 37 - Load Cycle Count - 184
I think I will shut down the system for now and turn int on only when required until there is a real solution.
Kind regards,
Webaccess - Saiyan_PrinceAspirantOK, I'm officially worried about the life expectancy of my WD20EARS. Here are the SMART readings:
DISK 1
Raw Read Error Rate 0
Spin Up Time 8550
Start Stop Count 12
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 106
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 10
Power-Off Retract Count 9
Load Cycle Count 1978
Temperature Celsius 43
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
DISK2
Spin Up Time 9108
Start Stop Count 14
Seek Error Rate 0
Power On Hours 117
Spin Retry Count 0
Power Cycle Count 12
Power-Off Retract Count 11
Load Cycle Count 2255
ATA Error Count 36
Load Cycle Count seems a touch higher than I would expect. If the general rule of thumb for LCC is ~300,00 before the hard drive begins to fail, and I have my ReadyNAS DUO on 24 hours a day, then according to my calculations, the WD20EARS would last about 1.7 years. I'm not sure if I want to use wdidle3.exe to disable the timer as others have tried with mixed results. Should I start looking for new drives now? Hopefully RAIDiator updates could fix this problem. - roadfunAspirantI really hope 4.1.7 adopts a method to reduce the LCC before it goes final. These are one of the more accessible drives and with it on the HCL (though with a different suffix than almost any of us seem to have) more and more customers are going to get burned.
roadfun wrote: I really hope 4.1.7 adopts a method to reduce the LCC before it goes final.
Fixing the LCC issue would probably require help from WD. It would be nice to have a fix in place though.roadfun wrote:
You can be "burned", but the onus is on you to check to make sure you get the compatible version of a drive mentioned on the HCL. The information is provided for a reason. - g17ssAspirant
Webaccess wrote: Hi All,
Firmware - 80.00A80
Right now my LCCs are 200-250 but haven''t moved since I've been copying files for the last 24-48 hours. One thing that worried me were the ATA Error counts.
Disk 1:
Previous count: 36
Current count: 42
ATA error count has increased in the last day.
Disk 2:
Previous count: 18
Current count: 24
Disk 3:
Previous count: 6
Current count: 12
These also haven't moved for the last 24-48 hours. I will be adding my fourth 20EARS within 24 hours and report my findings, but hopefully everything is A-OK. - roadfunAspirantFWIW I have one of those drives installed. ATA error count was 24 and has stayed there vs 0 for my WD10EADS which has been running for nearly a year. From post in the Beta forum it appears either WD will have to do a firmware patch to deal with LCC or we have to get lucky and Netgear finds they can set the timer in 4.1.7 (apparently the x86 firmware can do this for some models of WD drives).
- KennyKentuckyAspirant
g17ss wrote: These also haven't moved for the last 24-48 hours. I will be adding my fourth 20EARS within 24 hours and report my findings, but hopefully everything is A-OK.
^^ any news here??
I've found a German article about the LCC problem but some users posted here wdidle3 isn't supported by the EARS - is that true?
http://wiki.ubuntuusers.de/Baustelle/WDIntelliPower - roadfunAspirantI detailed my experience with the WD20EARS on this thread:
viewtopic.php?f=66&t=40222 - KennyKentuckyAspirantThank you for the link, I already read it.
I wrote WD and they answered the following:Leider ist es wirklich so.Ich kann Ihnen nicht garantieren , dass der Workaround mit der WD20EARS zum Erfolg fuehrt.
Sie koennen es selbst testen , aber vielleicht ist es empfehlenswerter eine andere Platte aus unserem Sortiment zu waehlen.
Translated it says:
Unfortunately, it's really that way. I can't guarantee you that the (WDidle3) workaround with the WD20EARS leads to success.
You can test it yourself, but maybe it is good to choose another hard drive from our product line.
