chano22000
Mar 13, 2010Aspirant
WD20EARS just added on the official HCL - mistake and issues
The official HCL has (quietly !) been updated for Sparc based machines with a 2TB WD desktop class drive: the WD20EARS (http://www.readynas.com/?page_id=82). This is in principle good news as the WD20EADS which might have been a candidate (if not discontinued in a near future) seems to have a lot a quality and compatibility issues.
But ... :
1) The HCL mentions the exact version to be used: WD20EARS-00R6B0. Googling the reference does not provide any answer (but the WD20EADS-00R6B0 which is well known). AFAIK, the current available version of the drive is the WD20EARS-00S8B1.
There should be an error in the HCL or the new entry is useless !
2) No restriction appears on the RAIDiator version to be used meaning by the way that the new 4K sector size, which implementation starts in high capacity drives such as the EARS, is fully supported since the beginning. It's amazing as other vendors have delivered updated firmwares for that specific purpose (and keep partitions aligned or performance may degrade significantly).
Or will the 4K sector size be supported by RAIDiator 4.1.7 as current beta "adds support for WD drives that don’t support TLER" (= WD desktop drives) ?
And does this new entry in the offical HCL mean that LCC issues are now fully tackled by RAIDiator 4.1.7 (since the EARS has the same green features as the EADS and WDIDLE is not supported by WD on newer drives), even though some users report recent WD firmwares do not count any more Intellipark related LCC in the Smart infos ?
Please Jedis clarify and thanks to still supporting early (Infrant ...) adopters !
Regards.
But ... :
Regards.
- bbqAspirant
kamlung wrote: manocc wrote: POSSIBLE ALTERNATIVE to WDIDLE3?
I have 4 WD20EARS-00MVWB0 and plan to install them in my nv+ in the next few days.
From my research it seems clear that the LLC issue has to be dealt with and I see that the popular solution is to connect the disks to a separate machine, boot a dos environment and use WDIDLE to increase the idle timeout.
I came across this alternate solution and I'll probably give it a try.
http://rant.gulbrandsen.priv.no/hardware/readynas-wd-caviar-green
It involves SSHing to the nas and using the hdparm command to effectively tune down the load/unload frequency - much more convenient than connecting to another box and booting dos. Has anyone tried this? Any experiences? I'll provide an update when I've had a chance to try it out but would love to hear from anybody who has experience with this. I couldn't find any reference to this in the forums.
any luck on this? i have mostly switched to macs and laptops and don't have a PC where i can run WDIDLE3 on the drive...
I too would be interested in this - I'm currently trying the Virtual Machine route on my Mac ... and just a little cynical that it will work via a USB external drive - shoshanna00AspirantWhy not? i think there is nothing impossible in it.. Have you already tried? And what?
- F_L_TutorI have two
WDC WD20EARS-00J99B0 in my Ultra 2 as well.
And I can see that the LCC is increasing very fast.
But checking with hdparm it seems that setting is already turned off (AdvancedPM=no):Ultra:~# hdparm -i /dev/sda
/dev/sda:
Model=WDC WD20EARS-00J99B0, FwRev=80.00A80, SerialNo=WD-WCAWZ1395124
Config={ HardSect NotMFM HdSw>15uSec SpinMotCtl Fixed DTR>5Mbs FmtGapReq }
RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=50
BuffType=unknown, BuffSize=unknown, MaxMultSect=16, MultSect=16
CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=3907029168
IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120}
PIO modes: pio0 pio3 pio4
DMA modes: mdma0 mdma1 mdma2
UDMA modes: udma0 udma1 udma2 udma3 udma4 udma5 *udma6
AdvancedPM=no WriteCache=enabled
Drive conforms to: Unspecified: ATA/ATAPI-1,2,3,4,5,6,7
Is there anything else to do or is wdidle3 the way to go?
Edit: running FW 4.2.19 - F_L_Tutor
F.L. wrote: I have two
/dev/sda:
OK, did a check with WDIDLE3 and disk were sat at 8 sec idle.
The wdidle3 /D changed it to disabled..
