hksscom's avatar
hksscom
Apprentice
Apr 22, 2015
WebGUI: ability to launch Backup Button job from WebGUI
I found no way to start the Backup Button job queue from the GUI. The only way is to physically push the button on the NAS.
As a workaround, I use "NAS Utils" on Android to manually start each job. You can start each job, separately, through the WebGUI too. Perhaps add a button at the top that says, "Start Backup Button Jobs".
Would also like to see the ability to re-order (re-arrange) the jobs defined for the button. Prior to OS6, this was possible.
ProSupport for Business
