Ron23
Dec 15, 2023Tutor
AC1900 C7000v2-routerlogin won't launch
I launch my browser (chrome or edge) and enter: routerlogin.net or the IP address of the router and the prompt to login doesn't come up using my new machine. It does launch using an old machine.
I don't want to do a reset on the router because I don't want to have to configure it again.
Any ideas on what I should do to make it work in my new machine?
I disabled my VPN in my new machine and now the window to login to my router pops-up. I put in my credentials and it allows me to login but all I see is a white blank screen.
Using my older machine continues to work fine.
It seems I'm getting closer after implementing some of your ideas but I'm not there yet. Please continue to send me suggestions.
Thanks.
No idea if this would help:
https://www.downloads.netgear.com/files/GDC/C7000v2/C7000v2_UM_EN.pdf -> Avoid Blocking on a Trusted Computer .. define the new machine there
- Ron23Tutor
schumaku. Thank you for the suggestion.The strange thing is that I have even connected my new machine directly to the modem with an ethernet cable and the routerlogin prompt still doesn't show up. Other than this prompt not coming up I can connect to the wifi and connect to the internet and do my work without any problems.
I have not tried adding the IP address of my machine to the trusted list so I'll need to do that.
If there are any other ideas out there, please send them my way. Thanks.
- schumakuGuru - Experienced UserSome overly secured Web browsers or security plugins might prohibit the access to simple devices like routers making use of the basic auth for the login if no HTTPS is available.
