LoveLuna
Jun 05, 2024Aspirant
Weird light inside my RNDX4410
So my RNDX4410 has a orange light behind the LANports.
saudade
Jun 05, 2024Apprentice
Orange or Amber?
Rear panel Ethernet ports Two LED status indicators are built into these ports. One LED indicates port activity. The other LED indicates connection speed as follows:
• Green. The port is operating at 1,000 Mbps.
• Amber. The port is operating at 100 Mbps.
• Off. The port is operating at 10 Mbps.
- LoveLunaJun 05, 2024AspirantNo no it is behind my Ethernet port. I opened the rear end panel
- StephenBJun 05, 2024Guru - Experienced User
LoveLuna wrote:
No no it is behind my Ethernet port. I opened the rear end panel(a) Is the NAS working ok?
(b) Are you also seeing a green LED for the ethernet?
(c) Can you check the ethernet connection speed
It does sound like it might be negotiating 100 mbps ethernet. If you can't check it easily, you could
- try a different ethernet cable
- connect using the other port in the NAS and a different port on the router (or switch)
- measure the file transfer speed, and see if you are limited to about 12 MB/s
- LoveLunaJun 05, 2024AspirantThere is no cable connected. And the Nas isn’t working only that one light is showing
