LoveLuna
Jun 05, 2024Aspirant
Weird light inside my RNDX4410
So my RNDX4410 has a orange light behind the LANports.
LoveLuna
No no it is behind my Ethernet port. I opened the rear end panel
Jun 05, 2024Guru - Experienced User
(a) Is the NAS working ok?
(b) Are you also seeing a green LED for the ethernet?
(c) Can you check the ethernet connection speed
It does sound like it might be negotiating 100 mbps ethernet. If you can't check it easily, you could
- try a different ethernet cable
- connect using the other port in the NAS and a different port on the router (or switch)
- measure the file transfer speed, and see if you are limited to about 12 MB/s
- LoveLunaJun 05, 2024AspirantThere is no cable connected. And the Nas isn’t working only that one light is showing
- StephenBJun 05, 2024Guru - Experienced User
LoveLuna wrote:
There is no cable connected. And the Nas isn’t working only that one light is showingNo sign of power on the front? (LEDs or LCD display)?
You say you removed the back panel. Can you post a photo of what you are seeing?
- LoveLunaJun 05, 2024AspirantNo lights or screen. Yes ofcourse
