dhl
Oct 13, 2009Luminary
Western Digital WD1002FBYS head click noise (#10987106)
Hi Everyone, I need help with what appears to be a compatibility issue with the ReadyNAS Pro Pioneer and HCL approved Western Digital drives. For background please see: Strange Problem with West...
claykin
Oct 14, 2009Aspirant
Hmmm, looks OK.
Have you tried to take those disks and connect them to a PC SATA controller, power up to a DOS prompt and listen for the same sound? If they're quiet it indicates the issue is either in the WD firmware or the way the NAS/Linux talks to the disks. I wonder is other Linux users of this model disk complain about this issue?
I found this page on the WDC website that may indicate your disk does not have the latest firmware. If a new firmware is available it can sometimes be like pulling teeth to get WDC to send it to you.
http://www.wdc.com/en/library/cs/2579-701321.pdf
Also, have you checked the jumper options? Not sure I'd touch them without doing research first!!!
http://wdc.custhelp.com/cgi-bin/wdc.cfg ... faqid=3335
