dhl
Oct 13, 2009Luminary
Western Digital WD1002FBYS head click noise (#10987106)
Hi Everyone, I need help with what appears to be a compatibility issue with the ReadyNAS Pro Pioneer and HCL approved Western Digital drives. For background please see: Strange Problem with West...
dhl
Mar 04, 2010Luminary
OK, 4.2.9 is installed and running.
No change to the drive behavior, still same non-stop, continuous clicking immediately upon boot.
I download all system logs then waited ten minutes and downloaded again.
Load cycle counts are low and holding steady for all four drives -- no change after 10 minutes of clicking
I'll send the zips to your sig address so you can take a look. I'll also leave the ReadyNAS on and check again later this evening.
Thank you!
Thank you!
