dhl
Oct 13, 2009Luminary
Western Digital WD1002FBYS head click noise (#10987106)
Hi Everyone, I need help with what appears to be a compatibility issue with the ReadyNAS Pro Pioneer and HCL approved Western Digital drives. For background please see: Strange Problem with West...
dhl
Mar 07, 2010Luminary
@Chirpa,
Re: Load cycle counts -
After some experimentation here's what I've found -- I left the ReadyNAS on for several hours, checked the logs and found that load cycle counts were unchanged for all disks.
I then powered off the ReadyNAS for the night. I turned the unit back on the next day and found that load cycle counts for each disc had incremented by one.
So it appears that load cycle counts for all disks increment by one only when the unit is power cycled. This appears to be correct behavior unrelated to the clicking noise.
Hope this is useful info. I'm happy to repeat this test and generate and send the logs if you'd like.
