chaps's avatar
chaps
Western Digital WD30EZRX 3TB in Duo V1
Hi,
I was just about to purchase the WD30EZRX 3TB for my Duo V1 but noticed they're not on the Compatibility list, only the Duo V2.
Does this mean they won't work at all in V1? As I'm just using my Duo as a backup solution...
Thanks,
Rob
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    3TB drives won't work in the v1 (they may be recognised but less than 1TB would be usable as there's no GPT support). 2TB drives are the limit for the v1.
ProSupport for Business
