tommychan
May 07, 2008Aspirant
What about adding drivers for USB modem?
Add driver to support USB fax modem and make it as a printer device (print to fax) so that I can send and receive fax anywhere in the world. Or is there already someone using a USB fax modem? If ye...
mh5bl
Jul 17, 2011Aspirant
PapaBear wrote: Considering the interaction needed to send a fax, it would seem to me to be far more efficient to use the general purpose PC you have. The ReadyNAS is not a general purpose PC (afterall there is no monitor or keyboard attachements), but a file server. For that use it is great.
using it as a fax server could not mean that you need a keyboard and monitor. this can be done tho a web interface.
people use the unit as a web server and a bit-torrent server. it used as a fax server will just make it more handy in the SOHO environment.
as web server are normal out in the cloud and SOHO do not on the hole use bit-torrenting
